@Tirtband
If SuperUser app is installed and "Enable Superuser" is checked then you should have root status and be able to do the following:
On the ES File Explorer Menu, where you found the "Root Settings" you should now be able to select ALL the items in this section:
1) Root Explorer
2) Up To Root
3) Mount File System
4) Back Up System App
5) (un)install apk automatically
If you cannot, then root status has not been granted, which could explain the google play store's behaviour.
If you are definitely rooted, then un-install google playstore and follow the steps again to re-install it.
I would give up on trying to use your Kindle as a removeable device on Windows XP. If you can get ES File Explorer working that should work perfectly:
Make sure you have created at least one share on your Win XP computer. Although not advised, you can right-click on the C drive and share the entire drive if you wish.
On your Kindle, add the share on ES explorer using the WinXP IP Address (remember this can change unless you have given it a fixed IP). If you have a User and Password, add these. If not select anonymous.
1) Root Explorer
2) Up To Root
