I just bought a used Kindle Fire hd and it's at 7.4.3, which root will work with this version?
I'm on 7.4.6... How should I go about rooting my KF HD?
Bumping this cause I haven't received any advice
Sent from my DROID RAZR HD using Tapatalk 2
My Kindle fire HD 7" software version is 11.3.1.0 ? no where near the 7's you guys have? why is that? and how can i root it?
Well, 7 might have been the most updated version of, the onboard firmware at the time. This method should work fine for you as well.
Remember to follow the instructions carefully and you should have a rooted kindle at the end of it.
that version is from the "new" 7 running Fire OS 3.0 . it might be a while until a root is found for that device. these methods wont work :/
so what your saying is if your on 11.3.1.0 this guide to rooting wont work, but is there a way to downgrade to 7.2.3 or other workable firmware from 11.3.1.0 new to kfhd 7 aswell as rooting it
it cant be done because its a newer model with different to similar hardware, but your in luck because i just found a thread to where theyve found ROOT for 11.3.1.0. be aware for anyone trying this method on an older model kindle will NOT work. this is for kindle(2013) Model.
[Root] Kindle Fire HD 7" 2013 (KFSOWI) 11.3.1.0 - xda-developers
First off great job I really like the comprehensive instructions. I have the kindle fire HD 8.9 and Im having issues rooting my device. I have the Adb files installed and have run the bin4ry version 31 however when I try to use quemo root it says access denied. I have installed java and downloaded the runme.txt but I am stuck on what to do next. Thanks!
