andrizoid
Android Expert
I don't have an "apply sdcard update." Should I select flash zip from sdcard?
yes
it says that it cannot find the file when i try to install with usb toggle in recovery. i do not know what i am doing wrong have tried numerous times. please help
Sorry guys but this isnt working with evil eris at the moment. I'm working with the dev to find a fix
Sent from my Eris using Tapatalk
back up your apps using astro or whatever program you use.
copy your SD card onto your computer and then delete everything off of it.
download this file and make sure its the only thing on your sd card
boot into recovery mode (volume up+power)
select partition SD card
select partition SD card again and wait for it to finish
choose ext 2 to ext 3 and wait for it to finish
hit volume down to take you back to the main menu
choose toggle usb
download and place this file in your sd card
a2sd-2.5-signed.zip - download now for free. File sharing. Software file sharing. Free file hosting. File upload. FileFactory.com
disable usb toggle and use volume down to return to the menu
chooseflash from zip and choose the file that you left on the sd card
let that load and return to the main menu with volume down
select enable usb
open up your terminal program on your comupter
go to your sdk tools directory
run "adb shell"
run "/system/bin/a2sd install"
run "reboot"
now your good
if your using a mac you will need to type "./" in front of the commands
do not type the "" for any of the commands.
do not type "run" in front of the commands either, just what is inside of the quotes
Flashed and it works! 158 mb internal memory! Will post updated Rom when I get home
i have no idea what happened but after installing app2sd i cant load past boot screen. help!
uploading right now
Closed as requested by the OP.im going to request that this thread be locked. will continue posting updates on the Evil Eris thread.
