IGO for android (desire Z)?
Status
Not open for further replies.
I'm assuming IGO is a GPS of some sort. Android has that baked into it to begin with and there are several 3rd party apps on the market you can buy.
If by IGO you mean igo, the board game, yes there are plenty of apps. GoDroid for example. Just search "igo" in the market or on a site lite appbrain. Dunno about that weird resolution, but they should work ok.
That thread has been pulled as the only way to obtain iGo for the Android platform currently, if it's not licensed and installed by your carrier, is to pirate it. The only retail version available appears to be for iOS.
iGo created Android version a year ago.
However, this version will not match screen resolution for HTC Desire Z.
iGo created software version for Motorola that should fit droid-like widescreens - called Motonav.
I installed it - works like charm.
Ofcourse - you should check for licencing and buying legal version... ;)
In other words you installed software licenced for another device, which isn't available as a standalone retail product, on your handset. That is a perfect definition of piracy. :mad:
/thread
Status
