IMEI Problem!!!!!! HELPPP!!
rohin26
I flashed a JB ROM to my stock ICS ROM on my international S2 and my imei number keeps coming and going for away, it'll be there one second and if I restart it'll go away then come back randomly. I can't find any solutions anywhere, NEED HELP!!
Do you have a connection to your network and can you make calls, send SMS, use data etc? If so then it's probably a glitch and nothing to stress about. If not then go to Settings/About device and check the Baseband.... if that is "unknown" then your /efs folder is likely corrupt.
no i dont have connection, yeh it is unknown, but how can it be corrupt from just flashing one ROM? im back on my nandroid back up now though and have a back up of all my efs stuff
Restoring a nandroid backup will fix IMEI issues, Slug. :)
It happened to me once and I restored my backup and, viola! Good as new! :)
