Importing contacts from old SIM
Hi everyone,
Just got a new HTC Desire and it is absolutely wonderful. Still getting to grips with it, and enjoying the forum for all the hints, tips and tricks.
I do have a query though - although I have followed the quick start instructions, I cannot import my contacts from my old SIM card. And now, my old SIM card is not playing in my old phone (SE C905) so can't try to send them as a vcard via bluetooth.
Any suggestions would be appreciated.
Welcome to Android Forums!
Congrats on your new handset. I've moved your post to the HTC Desire forum, where the question is more appropriate.
Enjoy your stay. :)
welcome,
If you have the contacts on a pc as well (in outlook or livemail for example), you could export the contacts as a .csv file and then import it into googlemail. then your phone will sync with googlemail and the contacts will be on the phone.
or install htc sync from the sd card that came with the phone onto a pc and use it to sync your contacts from outlook.
