Importing contacts onto epic
Brian2071
Is there a way to import my contact list from my old phone (VZW) to my Epic
without having to enter each name and phone number?
I'm talkin about everything; maybe try Googling ur previous phone & exporting contacts & see what u find...
If it's a dumbphone, probably not unless you can take it to the Sprint store and they have the right cable to hook it up to their little copying machine and export it over.
Check olut "goosync" to sync from BB to google/gmail. Then sign in to your gmail on the Epic and you're syncing.
