Help In Call Volume
Clappy101
Hi I have recently replaced my front speaker and I can now successfully hear music, However when in call the volume barely works the person on the other side needs to shout for me to hear them even the slightest. Has anyone else had the same problem after replacing a speaker ?
I have tried using a volume booster and factory resetting the phone but neither helped.
Does anyone know if in call volume comes out of the same speaker as media ?
Thanks, David
With no earphones connected music, video etc outputs via the external loudspeaker on the rear. Normal phone calls are routed via the front earpiece unless using the speakerphone feature.
are you sure because when i play music it comes out of the front speaker, and before i replaced the speaker, the only sound i could get from the alarm from the rear.
If the sound does come from the front speaker why can i hear media from this speaker but not calls ?
Thanks, David
