I barely get 5 hours use on a good day. This battery makes me sick
Do some research and put some effort in. The battery life will then improve.
You're using it wrong. Stop blaming the battery, it's the same one as in my phone and mine lasts for two days, as do lots of other peoples.Do some research and put some effort in. The battery life will then improve.
Unless you are literally constantly browsing the internet for 5 hours straight, the batter is capable of lasting far far longer. If you ARE using the internet for 5 hours straight, I suggest sticking a microUSB adapter on your car battery to get you through the day.![]()
Ok I'm having issues... I used to have quite good battery life, now its dire.
I had it on charge last night. Unplugged it at 5.20am when I got up. Haven't used it. By the time I grabbed my phone to go out the door at 6.20am it was down to 89% WTF!!!!
I then spent my 45mins train journey on here... and I now have 72% battery... I'm starting to wish I'd bought my phone charger with me!
I've got everything turned off 3g/gps/wifi etc - and only turn them on when needed. I have a plain (ok its Pink) background, with 13% Brightness on, turned off Vibrations (that was just annoying), turned off auto updates...what else am I supposed to do.
Also it took a total of 14mins to shut down this morning...is that normal???
I dont think a 14min shut down is normal. My phone never takes more than a min.
Have You got a task manager running? I find that helps to kill off the unneeded apps.
Also have you tried the process on here?
psh, he's using it right, you're using it wrong!!.
Anyone who has a desire and makes the battery last 2 days is using it wrong, you have an amazing phone, use its amazingness, drain the hell outta that battery, thats a batterys raison d'etre. it lives to pass on its charge to others. Don't be so cruel to your battery, give it a reason to be alive.
its like making humans stop mating, "no no, don't mate once a day, you can survive doing it once every 2 days you know!"
wrong.
i wonder if this is actually misreporting the battery level, than giving any extra juice. I find it really hard to believe..
Battety saving tip!
I have tried everything to get longer battery, Even bought the extended battery with the bigger case on the back of the phone, It didnt even last as long as the original!!!
The best way for me and if you are willing to do so is to turn off the 3G down to GSM only and it will save your battery buy a large amount.
When you are in an area that does not have a 3G signal your phone constantly tries to find the signal and in doing this will drain the battery even when the phone is idle.
Give it a try, Hopefully you will notice the benefits i have.
Settings>
Wireless&Networks>
Mobile Networks>
Network Mode>
Then change to GSM only. DONE!
