i hate to be the bearer of this news,but i believe you have a hardware issue that will not be recoverable,from the combination of errors that you are experiencing.
as ocnbrze said,theres not much we can do with a stock phone.
#2 youve tried,i believe the factory reset freezes becasue the stock recovery is unable to mount/wipe data
#1 we have not really tried,if im understanding correctly,as the file you tried was an unsigned radio file,and not a full,signed ruu. the prollem we will have with this option is that later ruus are,for some reason,not available for inc 2. the latest ive seen is 5.10.605.9.
if you want to,you can use these directions to help us find oout a few things about your current setup:
first download and install these drivers:
revolutionary drivers
then,download this small file:
mini-adb.zip
-unzip it,and place the unzipped folder onto the root of your C drive(not inside a folder)
-open a cmd window(with win 7,click start bubble,type "command" or "cmd" in hte search box)
-now change to your mini-adb directory(assuming you didnt chagne the name). type in the black cmd window that opened on your PC:
cd c:\mini-adb
-pull the battery in your phone for a few seconds. hold volume down,then power. hold them both until you see the white/colored writing hboot screen
-select "fastboot" from the hboot menu with the vol rocker/power button
-in your cmd window type:
fastboot devices
it should output your phones serial number. if so youre good to go. if not,youre apparently having a driver issue. i usually recomend these drivers from
Revolutionary:
modified htc drivers download and install the drivers(you should just have to run that file). afterwards,unplug your phone,plug it back in. make sure its in fastboot. as soon as you get a result from "fastboot devices" your ready to procede to the next step.
-in your cmd window,type(or copy/paste,is much easier):
fastboot getvar all
-copy the info that outputs here. right click in your cmd window,click mark,highlight it all in white. hit enter. paste the info here. it will help us know which ruu for you to run.
i know you said the PC wont recognize the phone,but hopefully thats a simple driver issue that will be fixed using the recomended drivers.
the other option,would be to simply try the latest ruu and see if it fails. if you want to try it, here is the newest that i know of:
Androidfiles RUU
you can try running the .exe file by running the download as administrator,place the phone in "fastboot" by selecting fastboot from the hboot menu,and plug it in when instructed.
if the .exe fails,you can extract rom.zip in the following manner,rename it to PG32IMG and flash in hboot from your sd card:
the .exe utilities can be finicky,so if you have trouble getting it to run, you can extract "rom.zip" in the following manner:
-start the utility
-check the "i understand" box to move on to the next screen
-hide the utility temporarily out of site
-search your C drive for "rom.zip". you will find it in a temporary location(it will be in a different spot each time you run the utility)
-open the folder location,and transfer rom.zip to a safe location on your PC.
-unhide and cancel the utility,youre done with it.
-rom.zip can be renamed to PxxxIMG and flashed in hboot,from a FAT32 sd card
___________________________________________________________________________________
if both of those fail,then the last option is as follows:
1)unlock bootloader via htcdev and install root and recovery with these directions:
http://androidforums.com/incredible-2-all-things-root/617779-guide-unlock-htcdev.html
note that the commands that start "
adb xxxxxxxx " wont work,as these are done with the phone booted,so just ignore those directions. youll have to follow the directions starting with
fastboot devices on each step,starting with the phone manually placed into fastboot mode.
when the directions say to reboot,then let the phone boot as far as it will,give it a minute,then pull the battery.
2)after root and recovery,you can flash this zip file in recovery to lower your main version,and allow an older ruu to flash:
http://forum.xda-developers.com/showpost.php?p=23169557&postcount=4
3)now,place the phone in fastboot again,and in a cmd window politely ask the phone:
fastboot getvar mainver
if it returns 1.00.000.0 then the zip worked,and you can try running the linked ruu above again. it should attempt to flash this time. pay close attention to wether or not it hangs when updating any particular partitions,or if it gives them all an <ok>
____________________________________________________________________________________
last and not least,we can verify the condition of your emmc with the following:
-power on to hboot
-boot to recovery (select recovery from hboot menu)
-open cmd window,plug in phone
-check for conectivity:
adb devices (should return serial mumber)
-run the following:
adb shell (should change prompt to a #)
dmesg | grep mmc0
it should spit out some stuff.
if emmc is ok,you should see something like:
Code:
c:\miniadb_inc2>[COLOR="Red"]adb devices[/COLOR]
* daemon not running. starting it now *
* daemon started successfully *
List of devices attached
HTxxxxxxxxxx recovery
c:\miniadb_inc2>[COLOR="red"]adb shell[/COLOR]
/ # [COLOR="red"]dmesg | grep mmc0[/COLOR]
dmesg | grep mmc0
[ 8.258270] mmc0: No card detect facilities available
[ 8.258941] mmc0: Qualcomm MSM SDCC at 0x00000000a0500000 irq 98,0 dma 8
[ 8.259094] mmc0: Platform slot type: MMC
[ 8.259307] mmc0: 4 bit data mode disabled
[ 8.259460] mmc0: 8 bit data mode enabled
[ 8.259582] mmc0: MMC clock 144000 -> 50000000 Hz, PCLK 96000000 Hz
[ 8.259826] mmc0: Slot eject status = 0
[ 8.259948] mmc0: Power save feature enable = 1
[ 8.260192] mmc0: DM non-cached buffer at ff011000, dma_addr 0x18feb000
[ 8.260345] mmc0: DM cmd busaddr 0x18feb000, cmdptr busaddr 0x18feb300
[ 8.421417] mmc0: new high speed MMC card at address 0001
[ 8.422576] mmcblk0: mmc0:0001 SEM04G 2.17 GiB
if your emmc is bad,youll see something like:
Code:
mmc0: failed to get card ready
mmc0: reinit card
mmc0: Starting deferred resume
mmc0: Deferred resume failed
im off to work,so ill try and watch if you have questions,and sure the others will stick around as well. ill be happy to help break it down later if needed,i know those directions are alot to swallow
