Help Incredible Swype
I have had swype on my Incredible for the past few months and then a few days ago an error message popped up saying that my trial period was over and I needed to update my subscription, the only problem is I have no idea how. I hate typing, please help me!
Did you get swype by signing up for the beta or did you find and use a apk? If you're not using the beta, sign up it's free! You could also try uninstalling with your file manager of choice and then reinstalling.
I had that same problem. I ended up uninstalling Swype Installer AND Swype, then re-downloading from the email link and re-installing. That seems to have fixed the problem - although I am concerned that I might run into problems the next time I turn off my phone to charge. (About every other time I'd charge my phone, I'd have to disable, then re-enable Swype or it wouldn't work.) Maybe the latest software update will have fixed that bug.
If i'm correct, Every swype that is installed on your phone has 120 days(at least with the newest update) before it expires.
Like said above, simply delete the installer and swype, then go log into ur acc and re dl the installer apk, and should be good to go!
What I got from some info on the latest beta release. it use to be 100 days.
If I am incorrect lemme know!
