How do I get my default QWERTY keyboard to display horizontally. I verified that the Orientation checkbox is checked under the Sound & Display setting. Is there anything else I need to set up?
Otherwise, this phone absolutely rocks.
Thanks in advance!
Some apps just don't work horizontally.
Is it a specific app or it is not working at all?
Its the stock keyboard.
Heres another tip to bypass the lockscreen swipe. Just hit the menu or home (can't remember which one off hand) button and you don't need to swipe your finger to unlock the phone.
Anyone?Is there a way I can check the "upload" progress when I'm sending a file (for example, a picture) to a gmail account?
It's kinda annoying how it says "sending message" that disappears after 2 seconds and sometimes it doesn't arrive in the account for like 20 minutes...
Thanks in advance!
OK, my first couple of dumb questions
1. Any way to rearrange the order of the screens? For example, to the right of the home screen is the "Favorites" screen, then the "Twitter" screen. Let's say I wanted to reverse them.
2. This was really aggravating... I use some complex character strings in passwords (not just letters and numbers as I maintain some fairly sensitive information) and I can not find the "greater than" (>) or "less than" (<) characters on the keyboard. Nonexistent? Hard to believe, but I can't find them.
- all three available alarms were defaulted to vibrate.OK, my first couple of dumb questions
HTC ...Welcome to HTC mail is one of the screens is there a way to remove this? I use gmail so no need for it...thanks!!
Anyone know how to link facebook and contacts. Some of them linked automatically while other have a link that I have to activate one at a time. Is there a way to let the phone activate all suggested links?
You will have to install the .apk. Here's step by step instructions:
1. Download the .apk file.
2. Copy .apk file to microSD card (either via mounting the phone or through a memory card reader.
3. On your phone, allow installing unknown sources: Menu -> Settings -> Applications. Check Unknown sources.
5. Open Astro, browse to your microSD card.
6. Select the Swype .apk file and it will go through the install process.
7. Once installed you need to make it your default keyboard:
a. Go to Menu -> Settings -> Language & Keyboard. Check Swype.
b. Open a new text message.
c. Press and hold the text input box. A box will pop up. Select Input Method, then select Swype.
Done![]()
Every time I try to download the .apk file I get the following message, "could not open a new window because you have already opened the maximum number".
HUH?
I don't think I have other windows open....
