andrizoid
Android Expert
This is a project Ive been working on for a while, its not finished, but its looking good enough that i thought Id give you all a taste of what it looked like.
Now available in Rom Manager under my name
This has been tested NOT to work on the following roms.
The widgets will still theme, and the apps may theme, but the framework-res will NOT work
This has be tested to WORK on the following roms
Included in this theme are
Instructions
Thanks To
This theme is not yet complete, heres a running list pf what Id like to do with it in the future
Screenshots!
Code:
Shadow Rom
Any Sense based rom
Code:
Any CyanogenMod HDPI rom
Code:
v1
[LIST]
[*]Wallpapers added to CMWallpapers
[*]Added files for Trackpad wake
[*]Removed labels for unlock etc on the lockscreen.
[*]Added weather skin for Weather Widget
[*]Added a build prop as an addon to enable OTA updates of the theme.
[/LIST]
b1
[LIST]
[*]Custom themed notification drop down
[*]Customized Black and white theme-base found on the internet, if this is your contact me please
[*]Transparent Astrid Widget
[*]SmokedGlass bootanimation that I will be modifying in the future
[*]Custom white-colors.xml for use in CyanogenMod Settings to change all the text colors to white.
[*]Transparent Fancy Widget widget
[*]Russel Square font
[*]Transparent Genie Widget
[*]Tall-Min red/white and white/white LP icons
[*]Droid X custom themed KB and libs
[*]Transparent Music widgets
[*]Transpreant Pandora widgets (?)
[*]Transparent and otherwise themed Power Control widget and Settings app
[*]Transparent Yr.No Weather widgets
[*]Custom LP app with Transparent LP+ Widgets
[/LIST]
Instructions
- Make a Backup
- Flash this through recovery
- After you have rebooted, open MetaMorph and apply the rest of the theme.
OR
- Since this is now available on Rom Manager, install it directly from there.
Thanks To
Code:
Lekky for his Tall-Min Icons
http://androidforums.com/android-themes/140958-icons-tallmin-updated.html
Crpercodani for testing
MathesonCody for testing
73v1n for the Smoked Glass boot animation
signals23 for his custom modded LP+ app
http://forum.xda-developers.com/showthread.php?t=764797
Code:
To Do
[LIST]
[*]Theme more widgets (SEND ME YOUR REQUESTS)
[*]Red in boot animation
[s][*]Add wallpapers[/s]
[s][*]Add trackpad wake[/s]
[s][*]Remove unlock images altogether[/s]
[*]Add small touches of red wherever possible
[*]Add LiveWallpapers
[/LIST]
Screenshots!
i may try this later when i have time
