Droiddude123
Still good. Wish I knew what they did to fix it after 2 returns, a replacement and another return.... I'm happy!
^^^^ So true. I can't believe I didn't unlock and put CROMI on it sooner. It fixed so many issues that I was having. It really is a shame that I had to do it in the first place, but at least there was something I could do rather than just having to live with it.
I have issues with mine, but I'm still happy with the device. I guess it's the level of tolerance we each have to glitches. That said, I'd seriously think twice before getting another ASUS device.
I have not explored flashing a custom ROM. But I am bootloader unlocked and rooted. I've read in multiple forums now that Cromi seems to fix all issues that ASUS seemed to struggle with. I may give this a shot.
I'm a big fan of the easy bootloader unlock. I've never been one to worry about warranty. If something fails, it's gonna be hardware, not my firmware tinkering. And if it's indeed hardware, I can make a good warranty case that unlocking had nothing to do with the problem.
You have to be unlocked, and rooted with custom recovery installed. Once you agree at that point, download the rom provided by the link in the all things root guide. Once downloaded, flash that in custom recovery. After is done installing, reboot and you'll be running cromi
Not sure if this was brought up or not but I did some research on slow TF700T and found a reference to limiting the number of background processes under the developer options. I enabled developer options and limited background processed to 4. All I can say is I wish I found this sooner. Night and day difference. The tablet is super responsive to changing and opening apps. I have not found any downside to this setting so far but so far, so good.
Anyone else found this recommendation to be helpful?
Sounds great! How/where do I enable developer options?
I returned it a day later.
It makes sense that this helps the lag issues, but it does cripple the multi tasking capabilities. Part of the rain ios runs so smoothly is because it prohibits simultaneously running tasks. It's too bad Asus couldn't fix the issue where the developer who makes cromi could.
