TennisProNB1
Last night I bought my new Inspire 4G from AT&T. The phone came with Android 2.2.1 OS from the factory (Don' t know if that bit on info matters). I did my research on-line on multiple forums to find out the easiest and best way to root the phone. I went ahead with the Super One Click root program and this where the problems happened. I did the process exactly how it was stated in the video from TheUnlockr site and on the computer it said your device has been rooted and then it says to re-boot the device. I did that and the Superuser app that is supposed to be in the all apps tray was missing. Before i rebooted, the app was there, after reboot, its gone. The phone wasnt rooted, any idea of what the problem could be? If anyone can shed some light on this it would be amazing. Thanks in advance.
Then.....i tried something else...mabye is related...
OK so after i tried the super one click tool and that failed...i tried the simple one tool by bubbly from xda and that failed...I think....all went perfect till I had to use the terminal emulator to input the first line of code /data/local/tmp/rage...and when i pressed enter on the phone...it came back not found...and I had no sound on my phone....
any ideas?
Drew
any ideas?
Drew
... rite now the fone is on the stock rom from ATT....so i was thinking of trying it again...with my new one...but do you have idea as to why it would say "not found" when putting the first line of code into the emulator?
