Hi guys. So I tried manually updating the software for my phone using the firmware from huawei website. Unfortunately, by being a rookie, I did not notice that this firmware was for a different carrier (cricket) and I am on MetroPCS.
I did this by copying the dload folder onto my micro SD card and then doing a software update via SD card. It was successfully installed. However, since it is for the cricket carrier, now my phone won't connect to anything, and I can't do anything with it. It shows a constant message that states:
"Sorry!
The process com.android.phone has stopped unexpectedly. Please try again. " (force close)
I write this thread to:
1. warn future users to not do this software update unless you are on the cricket network.
2. Also would like to know if anyone out there is able to get the correct (Metro PCS) dload folder so that I can install that software back in my phone.
3. To know if there is anyone out there that can fix my problem
I also noticed that my phone reads "unknown" for my baseband version. This should have numbers on it.
"Sorry!
Even if it isn't, It will do what you want it to do
