Root Installing smooth blue circle battery help
egernant
I just searched the forums and google with no luck. I really want to add the blue smooth circle battery icon to my phone running Senseless Redemptive but haven't been able to locate a good download link that will ONLY change the battery, not the other icons and especially not the notifications drop down menu. Does anyone know of a good link to the zip file?
Thanks!
does it work on a rooted phone with a stock ROM, havent changed it yet
No, not unless you're running one of the stock ROM's that are deododexed (sp?). Virtuous has one and a member here, ACD168, made one as well. It is stock ROM but deododexed so that you can apply themes and mods. If you're not interested in jumping into custom ROM's just yet but would like to mod your phone I would highly recommend one of these ROMs. Good luck!
great info Worm! Helps a lot im gonna look into one of those. Im worried that some custom roms dont work with Slingbox, gps, etc. so I dont wanna change to much. Plus I like the way my phone is running, 1295 quadrant score and battery seems normal.
Virtuous 3.2 is one of the closest to stock out there. You should be able to do everything on Virtuous you can do on stock. It is deodexed so these mods can be done.
Make sure you have hboot 0.92 so you can flash the ROM. You'll get reboot loops on any earlier version of hboot.
