When I first got my Mot Droid Bionic, the GPS worked amazingly good. My home has a metal roof and I was able to see enough sats to be able to get a bearing. I tested it by disabling the wifi and 3G and the GPS status showed several sats. Now, with 3G and wifi on it won't lock on to the sats. Also now I have to have both on to show the accurate location on the map. If I turn off wifi the map location is off by about a mile. It dosn't matter if there is a wifi signal or not. Is this something that was "updated"? I can take it and a high end handheld GPS into the woods and the Bionic will lock on almost as soon as I turn it on and the handheld GPS takes 5 to 10 min to lock on.
