Android Version: 2.2
Network: telia sweden
Taskiller Used?: nope
[Optional]Are You rooted & which Rom: yes, stock
Issue:
Hi people!
I rooted my desire several months ago but I have no idea if this is the issue. I keep running low on internal memory. So I delete an app or two and things are fine for a few weeks and then I'm low again. This has repeated over and over again and I'm now having to delete things I use daily just to get the damn phone working. It seems as there is a leak or something, or that something is taking up more and more of the space. Any general ideas here? I rooted, but that's the only thing I did. I haven't changed the rom or anything like that and I'd prefer not having to screw around with custom roms and app2sd+ as it seems complicated as hell. I'm pleased where I am, apart from low disk space that keeps lessening as it seems.
EDIT:
I've milked out as much as I can from the app2sd solution (NOT PLUS, just the "move apps to sd by force" method)
Issue:
Hi people!
EDIT:
