DaisFlaque
Android Expert
Hey ever try to re-download?... it could all boil down to a bad download...
Plus... it doesnt work every time... but i may have a trick that just might get your lil guy running...
If ctmod installs than you might be able to do this... its been so long... I'd wait till another like lordvincent, wet, cm or vice gives some approval... but you can take a pc grab a copy of 7zip and...
1. Get BOTH copys of HB and CTMOD.. side by side in a empty folder..
2. Do not unzip... just OPEN AS ARCHIVE open both. Orherwize it will ruin the singing on the file...
3. Replace the system folder.. from CTMOD to HB overwrite the entire folder.. Do not merge.. even delete the one in HB zip before copying over.. than copy to sd card. And flash...
Try this ( as I mentioned above ) :
1. Format your sdext
2. Install the ROM ( I'd try CTMod, but you can try whatever fits you )
3. Let the phone boot up normally, don't do anything, just let it start up
4. With CTMod installed ( sorry, don't know how HB does it ), go to >>>settings>>>CtMod Settings>>> Kouma mod and change the radio button to "DATA" and save it.
5. Now hold the power button down for a second or two until you see the menu.... Choose REBOOT, then RECOVERY
6. Once the phone is in recovery, RE-FORMAT the sdext (not sd-card )
7. Then reboot system..... be patient, it may take a little ( first boot can take up to 10-15 minutes in some cases )
Let me know f that helps
Did you try my suggestion?
no i haven't, it appears somewhat difficult for my "lack" of skill sets
i still may install the zips to a folder on my desk top and see how far i can get using your instructions.
i guess the big deal is i'm trying to find out why my daily phone won't work with HB...it's not that i really have to have that rom but it's driving me crazy why it works on one phone but not the other.
thanks again for everyone's help
lots of great advice here but i swear i have done at least 4 back to stock odin's and double that or more on the HB install's/partition/formatting/3 different sd card's and so on.
i did a full back to stock on my spare today and it worked 100% then loaded restore and was back to where it was an hour before.
my daily phone loops then hangs or just hangs...crazy crazy..
just so no one misunderstands...my daily phone works fine(as far as working)...i have a restore of CTMod 3.80 i just restore on it when i'm done trying things to get HB to work.
can i load terminal emulator and run some commands to see what i have or don't have and maybe see if my internal memory is jacked up?
here is a post from the HB thread...guy was having the same issue as me but seems to have got it going:
Quote:
Originally Posted by Capn069
I cleaned the Cache and did a system reset and all I get is boot looping on startup.
skater:
Try flashing back to stock, Factory reset, then mount your partition in CWM and re flash.
here is what i found using df command...
$ df
Filesystem 1K-blocks Used Available Use% Mounted on
tmpfs 145132 80 145052 0% /dev
tmpfs 145132 0 145132 0% /mnt/asec
tmpfs 145132 0 145132 0% /mnt/obb
/dev/stl14 95744 6480 89264 7% /cache
/dev/stl12 164272 108500 55772 66% /system
/dev/stl13 163768 97008 66760 59% /data
/dev/block/vold/179:1
14587288 440360 14146928 3% /mnt/sdcard
df: /mnt/secure/asec: Permission denied
But there is a data partition...here is what i found using df command...
this is what i see in the apps area:
downloaded
102MB used--------859MB free
all
on SD card
148MB used--------6.3GB free
running
100MB-------------151MB free
