If ctmod installs than you might be able to do this... its been so long... I'd wait till another like lordvincent, wet, cm or vice gives some approval... but you can take a pc grab a copy of 7zip and...
1. Get BOTH copys of HB and CTMOD.. side by side in a empty folder..
2. Do not unzip... just OPEN AS ARCHIVE open both. Orherwize it will ruin the (((singing))) on the file...
3. Replace the system folder.. from CTMOD to HB overwrite the entire folder.. Do not merge.. even delete the one in HB zip before copying over.. than copy to sd card. And flash...
where is that guy who was gonna teach me to sing????
hahahha
wellllll.......
got bored and tried the above quote.
ok i think i did it right but when i tried to copy the zip from the same folder that i modified i noticed that i didn't see the zip write to the card.
it just popped up on the E drive folder(honeybread).
loaded the card and the phone said no files ect..so i kept poking and punching buttons on the laptop and i zipped the HB that i had just modded.
put it on the card(still didn't see it write).
the phone then seen the zip and tried to load then stopped with error.
ok then my sd flew out of the phone when removing(still can't find it)
pretty powerful spring i tell you!
ok i grabbed another card and said i'll just go to downloads and add HB cause it's getting late...hmmmm
zip wrote to card like normal and then did the ext mount and flashed the zip.
samsung popped up on reboot then HB theme...then.......CTMOD??????
i'm like WTF???
it booted up to ctmod 3.80 so i went back and formatted ext again and booted...it is booting now slowwww.
no harm this is the spare phone
my question is...the changes i made to the zips i put on my desktop actually changed the HB zip that was in my downloads????
yes?
anyways it's almost fully booted but it is ctmod not HB.
do i need more singing lessons??? LOL
thought i'd let you know...was bored and thought i'd try it.
let me know your thoughts....thanks
