RunamuckRez
Member
Hey folks, cross posted from another thread that didn't get a response, but I'm really curious so I'm posting a new thread to see what everyones thoughts are..the original post follows.
Hey Gents,
I flashed xtrRom 4.6 yesterday from 4.2 4.2 was working really well, but for some reason I started getting issue's where I couldn't access my calendar and my sync. I would get FC whenever I opened one or the other. After reading how Titanium Backup can cause weird issues when you save system apps + data, I did the full wipe/factory reset/davlink wipe and just backed up user apps + data. Flashed the ROM, set everything up, ran TB and restored the user apps + data, presumably to the Cache. With 25 user apps give or take, I'm showing on internal phone storage 69 -71 mb worth of space. Does this seem correct? I was under the impression that with Cache2Cache enabled, the internal phone storage wouldn't be used. I did run Apps and Cache to internal just to see how much memory would be left and it was significantly less, but I figured I would have alot more space still open with Cache2Cache in effect. Any thoughts on this? I am also running Launcher Pro plus, and the weather + Toggle widget. I did free up some space by deleting all the skins.
Rez
Hey Gents,
Rez
