Root [International] Custom kernels
blulite127
Member
Anyone discovered a working custom kernel yet? Wanna overclock this thing and cant find a supported kernel thus far.
Whats everyones views on trying some of the s3 kernel varients??
Sent from my GT-I9505 using Tapatalk 2
Do NOT flash a kernel that isn't for your device
Also, Samsung is great at releasing source, so over clocking should be pretty easy
Finally, why overclock? If the phone isn't laggy, all you're doing is increasing the heat, decreasing battery life, and possibly causing damage
I just like to see how far the device can be pushed. Im mostly interested in using STweaks than just having a solid overclock runing.
Either way i need a custom kernel.
I'm pretty sure stweaks won't work unless gokhanmoral decides to change his mind and actually purchase an s4, otherwise we need to hope someone else with his great ability helps us out.
Looks like the s4 may have to be sold at this rate lol not much use in it being rooted if nothing works :(
lol I think you're being a little impatient. How long has the phone been available?
Anyway, gokhanmoral's siyah isn't the only kernel that can be used with stweaks (on the S3). Perseus kernel also allows the same tweaks (overclocking, audio, etc). So all is not lost. There are bound to be custom kernels developed for the S4.
I use dorimanx on my s2 to run stweaks. Any kernel will do as long as it gives.me.what i want lol
You won't see a custom kernel until Samsung releases source code for the S4 kernel. The best you can hope for until then is a modified stock kernel a la Chainfire or PhilZ, which obviously wont allow voltage/frequency table modifications.
Yeah i worked that out eventually lol, perseus caused a boot hang and then i tried another custom, cant recall which one but i then got a joot, yet was left with problems of no wifi, no sd card read/write, apps attempting unpermitted actions warnings and lost loads of sd mounted apps. I then tried adams kernel, which solved a couple of the issues (wifi/sd card) but i still recieved regular error warnings for unpermitted actions.
I bit the bullet and reflashed the stock os, which as it happened, installed as an update, this solved all the issues and once that was done i decided to flash with the latest MGA 4.2.2 update.
Im considering moving over the the google edition 4.3 rom but im not sure i can be bithered to reinstall all my apps and settings.
I would have really liked to have discovered how to resolve the unpermitted actiins issue withouy the need to reflash, but not to worry.
