D DroidFaller Well-Known Member Jun 22, 2013 #101 Anyone tried SlimBean Rom? Any thoughts on it? I just want to try it, but i want to know some feedback on the rom first.
S sherlock5545 Android Expert Jun 22, 2013 #102 I'm using it, it's been almost 2 weeks now. No issues so far, combined with Googy Max Kernel. Give it a try, it's very fast!
D DroidFaller Well-Known Member Jun 22, 2013 #103 What is format system? Can i just wipe data wipe cache wipe dalvic? It says to format system but idk what that is. Or does wipe data wipe system also? I have TWRP
S sherlock5545 Android Expert Jun 22, 2013 #104 If you do that it will remove your current OS from the phone. You don't need to do that, just factory reset, flash the new rom and then the gapps.
