[International / GSM] N00b here with rooted phone, need a root 101 course.
So about a month or two ago I was lucky enough to buy a Galaxy Nexus (gsm) from someone on Craigslist and he already had it rooted when I took possession of it.
The phone has been great and I have even tweeked it a little thanks to the AOKP ROM.
It's running ICS 4.0.4
It has a 3.0.34-CMPLUS-Tuna Kernel and maguro milestone 6.
I would like to upgrade to Jelly Bean, but to be honest I can't really follow the instructions I find on here, I'm not stupid when it comes to things but I feel like I am coming to the party late and because I didn't do my own hands on root just don't have the background to do it right.
Are there any "dumbed down" upgrading to JB for dummies type of instruction sets out there I can follow?
Thanks,
Rob
Thanks,
Rob
Wish I could help directly.... but if there was ever a place that could help, you've found it :)
Follow the directions from the link below, and perform a clean flash (There's two types.. clean and dirty, you need to do a clean flash because you're coming from ICS. A clean flash will *not* wipe your personal stuff from the SD, but it will wipe all of your user apps and reset the phone to default). Easy peazy lemon squeezy. ;)
http://androidforums.com/internatio...oot/605196-09-6-maguro-aokp-jb-build-1-a.html
If you have any questions, ask in that thread and someone will help. :)
Clean flash is essential
Great advice here so far. Just to give an actual explanation: first you need to unlock the bootloader using a computer, which will factory reset the phone. Then you can flash a custom recovery that will let you either flash a .zip to obtain root permissions on your stock ROM or to flash a custom ROM. ALWAYS ALWAYS MAKE A BACKUP AS SOON AS YOU FIRST FLASH THE CUSTOM RECOVERY to make sure you can more easily return to stock. Feel free to PM me for further instructions and clarifications.
