Okay, here's the "TL;DR" (too long--didn't read) version:
Q: can I get/install an OTA if I have a custom recovery (ClockworkMod) installed?
A: nope (the OTA will actually download, but the installation will fail unless you have a stock recovery installed)
Q: can I then just re-flash the stock recovery and then get/install the OTA?
A: yep (works just fine)
Q: can I be rooted and get/install an OTA?
A: yep (you'll lose root afterwards, though)
Q: do I lose root access at that point?
A: yep (easy to get back)
Q: what do I do then?
A: invoke custom recovery and re-install the su.zip root package
Cheers!
Here's the particulars of my little testing session tonight:
- initial phone state: VZW LTE/CDMA Samsung Galaxy Nexus running 4.0.2, rooted, with ClockworkMod installed
- flashed back to stock 4.0.1 (VZE/LTE/CDMA) [note: I did not lock/relock bootloader]
- powered back down
- rebooted in fastboot / bootloader mode
- flashed ClockworkMod custom recovery
- restarted phone
- got OTA notice; accepted and phone restarted,
- upon reboot, OTA install almost immediately failed (show little, green Android with red triangle and ! mark inside)
- flashed stock recovery back; rebooted; checked phone status (still 4.0.1);
checked for system updates--couldn't force update at this time (tested this again later on)
- flashed back to 4.0.1 stock; left stock recovery intact
- rebooted, waited for OTA prompts, accepted, rebooted, installed, was now 4.0.2
- flashed back again to 4.0.1 stock
- flashed ClockworkMod again over-top of stock recovery
- rebooted
- downloaded and accepted OTA
- OTA install failed (again)
- rebooted; got another system update notification
- OTA installation successful; again back to 4.0.2
- power down phone
- reboot into fastboot / bootloader mode
- reflash completely back to stock (4.0.1)
- soft-boot ClockworkMod and install su.zip root package
- reboot
- verified root access with Titanium Backup
- wait for OTA (system update) notification
- installation worked just fine
- rebooted
- checked system version, now back to 4.0.2
- check root access--root was "gone" (really, just inert)
- powered-down, flashed ClockworkMod, re-installed su.zip root
- rebooted, verified root access (yay!)
Fin.
Cheers!
- powered back down
- restarted phone
- rebooted
- power down phone
- reboot
- rebooted
Fin.
. Then, when I was all done, I still had to restore my Nandroid backup, too
[I am a little bleary-eyed this morning, LOL
