Im trying to figure out how to use one click instead of setting short cut with power toggles. Developer says you have to root in order to be able to use one click method on certain toggles to make them work.
All i want clean simple easy way to root it. Any help.
The best thing ever made for the Nexus. This toolkit does it all and I mean ALL. The toolkit does all the work for you. Choose an option and hit enter. Done.
