[International / GSM] Question on CWR
droidfan1
Say I brick my phone. I can't boot up without bootlooping. How do I get into clockworkmod recovery? (Since I can't use rom manager).
I'm assuming - fastboot by holding both volume rockers + power? Then go to options "recovery" and then that'll take me to clockworkmod recovery?
Yep, you got it...you'll have to power-down first, though before the simultaneious volume rockers and power press to put you into fastboot / bootloader mode.
I got a few boot loops last Friday testing the various root methods (that turned out to only work well for the GSM phones :p). Had to do some battery pulls, etc., but fastboot mode was always there.
Even if you don't have a custom recovery flashed, you can always flash it or soft-boot into it from fastboot.
An unlocked bootloader is awesome, eh? :) ;)
Cheers!
