[International / GSM] Random reboots since rooting?
Asterdroid
Android Expert
I've had a couple random restarts since I rooted.
All I've done is load CWM, load Nova Launcher as a system app, and give lightflow superuser rights.
Anyone else having this issue?
No random reboots for me...
I'm stock, rooted, CWM, and got most of my apps that I was running on the Droid X on the GNex.
Maybe "sandbox" (uninstall) each suspect app for a couple of days to see if one might reveal itself to be the culprit?
Cheers!
when did the reboots start? After one of those apps in specific or did you load them all at the same time then it started?
It started a day and a half ago. Only install I've done since then was desktop visualizer and the Google+ update.
I'm wondering if it's Trillian or Tasker since they both run in the foreground and I don't believe either have been updated for ICS.
Anyone else running either of those apps issue-free?
