Root [International] Need help with Htc one
don't worry i'll take you through it all and find the right ruu for you, I need those 2 numbers though in order to find it.
Yes you need to charge it before flashing any zips or RUU's to above 50%
(bootloader) modelid: PN0710000
(bootloader) cidnum: HTC__203
and there is a bunch of other info but u said u needed these
No I don't need that other stuff, that's perfect thanks, i'll go look now, stick your phone on charge for now, thanks.
Back in a couple of mins.
right I found it and lucky for you its the same as mine and one I also ran myself earlier awaiting the sense 6 update, here the link, download the file and then I will tell you what to do with it.
you have the European HTC One M7_UL
Guru Reset M7 3.62.401.1 - HTC1Guru
this file is for the following phones:
Stock ROM version for these types:
modelid: PN0710000
cid: HTC__001 (this is mine), HTC__E11
HTC__102, HTC__203 (This is yours)
HTC__405, HTC__Y13
HTC__304, HTC__032
HTC__A07, HTC__J15
HTC__016
allright, now waiting for it to charge to min 50%, won't take long, im downloading the ruu too atm , really thanks alot for your time and help ^^
okay 25% , so do i need anything else for it ? the ruu is done in 15 min, do i need anything else besides that ?
EDIT: my cwm is not touch version , it works only with the buttons , i cant touch the screen , is that fine or should i get the touch version ?
When the zip has finished downloading, plug your phone into the computer and copy the zip file onto your internal storage on your phone, again after the phone is charged to 50% or more.
after the zip is flashed you will be able to receive all updates.
Please hit the thanks button a couple of times if I have helped you.
okay thanks ^^ so if the zip is done, i just have to put in in my phones internal storage and nothing else ?
yup, nothing else, we are going to flash it like a custom rom, not run it from your computer, but it uses an aroma installer which requires a touch recovery.
oh.. do i have to download something else too now ? the ruu is still downloading, its over 1 gb... not that much left tho, and i forgot how to flash it actually... :p
ok, rename it to recovery for ease later on and put it in that min-sdk folder where adb and fastboot etc is please, the one you downloaded earlier.
@BRAINZ2013, that's the twrp ive just linked him to, its the best in my experience.
when the phone is charged, we are going to flash that recovery in fastboot mode, and then we are going to enter recovery, wipe and flash that zip RUU, you will then be back to complete stock, recovery and all and get OTA updates.
allright, its in the same folder, now waiting for it to charge , 36% atm and the ruu is almost done, I can still root it later and flash a custom rom or not ? i just need the stock atm
You can root when the device gets the update your waiting on . if I was you I would give it a week or 2 before you try and make a stable backup cause if the ruu isn't made yet for this new firmware . you will need a helpful tip next time . I have seen that where a device was useless til the ruu was made . was only 3weeks.
