could you check one other thing for me please, have a look on your phone, goto menu-settings-about-software information-software number ??? tell me what the number is.
perfect, its the 401 I was looking for, it means WWE Europe, that rom you downloaded has the 401 in it too, the first set of numbers is the version, but the 401 is the main thing that matters.
when the file has copied over, put the phone in fastboot mode (restart and hold down volume down button) again it should say fastboot USB on the phone screen.
Then open up a command promt again in the mini-sdk folder, (Control + Shift + Right mouse click and select open command windows here)
when done your phone will be like you first got it, you will have to set it all up, don't go rooting or flashing any custom recoveries, just set it up basic and then check for updates, I got 2 updates earlier today.
