Root [International] PhilZ CWM Recovery - Dummies Guide
PhilZ Recovery 6.25.4 is up! :)
"sort files using case insensitive order (adapted from @titanic-fanatic)
use new ro.loki_disabled for unified variants not needing loki
This way, we only need to set the ENABLE_LOKI flag to have a loki enabled recovery
No more need to set an extra ro.loki_enabled property
Only modification needed now is for jflte variants not using loki
Only jflteatt and jfltevzw do
We have to set ro.loki_disabled to 1 for all other variants in libinit_jflte
New device: Galaxy X Cover 2 (skomer)
New device: Galaxy S3 Mini (golden)
New device: Sony Xperia ZR (dogo)
New device: Sony Xperia Tablet Z (pollux)
New device: Sony Xperia Z1 Compact (amami)
New device: Sony Xperia S (nozomi)
New device: moto_msm8960 unified device (by @hachamacha)
New device: Galaxy S Advance (janice)
New device: Galaxy Ace 2 (codina)
New device: Samsung Galaxy Tab 3 7.0 SM-T211 (lt023g)
Download for i9505, 6.25.4.
Download for i9500, 6.25.0
Source
Strange i tried with DAP no good with resume download and tried chrome again and then started downloading,got now thanks been trying about 2 hrs for this..
6..26.4 is up.
You just can't get the staff these days. :banghead:
I've almost finished training Hawker's replacement...
... and he works for peanuts!
PhilZ Recovery 6.26.4 is up! :)
"- broken root: help victims of bad custom ROMs
This adds extra code to detect if two su instances are installed in /system/bin and /system/xbin
It will kill both and properly apply SuperSU
- fixing root on exit was never done what ever was user choice
- update libloki to latest sources
- fb2png: better error logging
- derp cm_moto_msm8960
- New: HTC One M8 (m8) support
- New: HTC One M8 sprint (m8spr) and AT&T (m8att)
- New: Note 10.1 2014 Wifi - SM-P600 (lt0wifi)
- New: Note 10.1 2014 3G - SM-P601 (lt0wifiue)
- New: LG Optimus L7 P700 (p700) by @ali.filth
- New: Galaxy Grand Quatro (i8552) by @ali.filth
- New: HTC One mini (m4)
- New: LG Optimus L7 P705 (p705) by @ali.filth
Download for i9505, 6.26.4.
Source
PhilZ Recovery 6.27.2 is up! :)
"libtouch_gui 1.18:
- confirm cancel nandroid jobs (prompt to press 'Back' twice or resume after 5 secs)
- vibrate after backup/restore operations
Download for i9505, 6.27.2.
Download for i9500, 6.26.6
Source
Just to let you and mr. Snail know that v2.29.2 is up.
Lots of backup/restore improvements especially concerning secontext.
I'll let old rusty take it from here...
Just to let you and mr. Snail know that v2.29.2 is up. :confused:
As it's your 46th Birthday today... I'll let you off old boy! :birthday:
(Now I know what your long suffering wife, Kerri, meant when she said that she, "Felt old age creeping on!" ;)
PhilZ Recovery 6.29.2 is up! :)
"- fix potential bug when verifying root and recovery state on exit
- merge "Fix verify_root_and_recovery menu selections":
- hide the Go Back button from confirm menu
- merge "Prohibit mounting/formatting swap partitions in recovery"
- add minitar binary to /sbin instead of busybox tar
- minitar: enable more options, enable long options, fix selinux backup/restore, enhance GNU tar compatibility
- revert RECOVERY_NEED_SELINUX_FIX patch
- enable seamless backup/restore selinux context using minitar binary
- TWRP mode: support backup/restore of selinux context
- libtouch_gui 1.19
Download for i9505, 6.29.2.
Source
(I see you're starting to get confused about things already... like version numbers :rolleyes:)
PhilZ Recovery 6.29.9 is up! :)
"- merge "Recovery: swap XY on swipe controls"
- shell pipe: set exit code to error if any pipe element fails
* this was causing backup state to be reported good while tar command failed
This is in my opinion an important bug fix to nandroid backup reliability
It is affecting all CWM recoveries since first versions
Download for i9505, 6.29.9.
Source
PhilZ Recovery 6.40.0 is up! :)
"merge "dedupe: fix BUILD_HOST_EXECUTABLE"
A small update for the dedupe backup
Only needed when using rom manager and such
Download for i9505, 6.40.0.
Source
PhilZ Recovery 6.40.1 is up! :)
"- proper libtar implementation: support backup/restore of selinux context inside archive
- dedupe: support backup/restore of selinux context by @Chenglu
- libtouch_gui 1.20: support custom key files (BOARD_CUSTOM_RECOVERY_KEYMAPPING)
Download for i9505, 6.40.1.
Source
