Hawker
Android Expert
Correct. Under that folder. Is it safe to delete all?
Only if you don't want a working device.
That's full of modules and libraries for file system access, wifi etc. So leave well alone.
Thanks a lot. Just making it sure. Because my external memory are low. Don't know which file is safe to delete.Only if you don't want a working device.
what are the steps you do the factory reset? is it thru the phone or thru CWMP? can you please guide me step by step to do it. i already back up all mu files from internal sd. thanksBut that's in /system which is not on your external sd card, and as far as your device is partitioned, it's not even in your internal sd card.
The best way to make as much space as possible is to backup your internal sd to pc, do a factory reset and wipe internal sd, then restore back anything you need.
Personally I never keep anything of my own stuff such as pictures, files etc on internal sd. I always use external sd. This way I know after I do full wipe I won't lose anything vital to me
hi sir ironass, im not asking about any root method. just askin sir hawker about the external sd, so that i can get a lot of memory.Are you asking for a step-by-step guide for your T-Mobile, Samsung Galaxy Note 2, SGH-T889, here?
If so, you should post your question in the All Things Root forum for the T-Mobile, Samsung Galaxy Note2, SGH-T889 as this is the Samsung Galaxy S4, International, forum and any step-by-step guide would be irrelevant to your model and firmware.
Good job someone's on the ball around here! :bebored:
A bit like that binty you had over the weekend!
