iowabowtech
root@android:/ #
What do you think about flashing a D802 4.4.2 Stock ROM (if I can find one) with TWRP? Would doing a nand backup and then flashing the D802 followed by a boot restore from the nand backup work? That is what they other link successed and it seems plausible.
Hmm, well if the kernels are indeed compatible between the d800 and d802, then yes I'd think you could flash a stock rom but remember this...when you ran Autorec, it installed a downgraded aboot and patched kernel in order to maintain working Loki. So, you'd need to install the patched kernel for the D800 directly after flashing the rom.
Rather than trying to restore from Nandroid, you might just install the D800 kernel in TWRP directly afterward. Those can be found in this thread (who's OP is also the author of Autorec):
http://forum.xda-developers.com/showthread.php?t=2680948
Specifically by following the download link at Patched Kernels > White Lines > D800 kernel. Those are flashable zips so that's perfect.
However, I would definitely have a nandroid backup made prior to trying any of this. If it fails to boot, you can always nand restore and regroup.
