Root [International] used note2 root file in my s3 by wrong help!
hi guys i want some help pls on my phone
i have rooted my phone with odin .. its galaxy s3 gt-i9300 with the room 4.1.2
and i choosed a root file that used for note2 by wrong
then i reinstall the 4.1.2 room again and i did wiped my data and factory reset
but the problem is the screen is untouchable ... every thing is working good
exept the screen is not Responds
hope u help me and thx
hello and welcome to AF!!!
i moved you to the internantional s3 root forum where folks who have your device can help you out better.
now flashing something not made for your device is a good way to brick it. you have to be aware of what you are flashing.
do you have recovery still? did you make a nandroid backup? if so can you restore it?
I think youre probably gona have to flash stock firmware onto it.
Its just done with Odin in the same way that you flashed the wrong root file :)
Check Sammobile.com and find the firmware suitable for your gt-i9300 and your country then flash the tar file using Odin :thumbup:
funkylogik i did that already plus i did wiped data and cache but the screen still unresponsive for any touch but every thing else buttons ,screen colors,and every thing is running well exapt the touch problem
ocnbrze thx for movin it ... no i don,t have any backups but i don,t care about the apps its not too many .... i,m afraid cause it may be a problem with something inside the device ,maybe something on the screen has been Crashed :(
Hello and welcome to the forum.
Would you be able to post a link to note root file you used please? It might help to figure out what it's done.
I'm a bit confused why flashing stock didn't fix it as it should replace what cf auto root does. I'd try flashing the i9300 version of auto root to see if it sorts it out.
sadly i did that too :( nothing happen
oh i forget to say something.. when i flashed the note2 auto root and i opened the phone the screen worked with some blue lines on all of the screen then the rom just worked but the problem just started
You can format system in recovery under mounts and storage. I'm not sure if it's an option in stock recovery though so you might have to flash a custom one.
