I am using SwitchMe app. Its pretty neat. It got me wondering if the Esteem is capable of multi booting. I find Ldrifta's ROM best for daily use but want to use PG's ROM for certain things.
Honestly dont know, but You know you are basically "dual booting" is you back up PG's and ldrifta's rom in recovery and you can switch between the 2. Actually partitioning and all that would probably just be a waste of time in my opinion, and plus restoring a back up is a lot less risky for oopsies![]()
actually dualbooting on a phone isnt like it is on a PC. The other 'boots' are on and boot from the sdcard.Honestly dont know, but You know you are basically "dual booting" is you back up PG's and ldrifta's rom in recovery and you can switch between the 2. Actually partitioning and all that would probably just be a waste of time in my opinion, and plus restoring a back up is a lot less risky for oopsies![]()
actually dualbooting on a phone isnt like it is on a PC. The other 'boots' are on and boot from the sdcard.![]()
it should be possible but I'm not going into the details of how its done etc etc. I dont support dualbooting mobile devices, but its doable.![]()
to be completely honest and this isnt meant to offend anyone, but the masses arent savvy enough and we would end up with countless bricks. And I for one barely to manage time to help folks out now lolToo bad I did not see this -- the only sensible response in this thread -- before I posted.
Why don't you support dual booting?
Oh and to answer the question of what GRUB is, its a bootloaderYou can put Ubuntu on a droid; I don't see why you couldn't get GRUB to work. I wonder how many people that responded to your post even know what GRUB is? Not to be mean, but I'm just asking. Save your 15 dollars, if it is possible, it will be done.
go check out the htc hd2. a true beast. the godfather of smartphones
