Hi everyone -
First of all let me say thanks for this awesome resource for rooting and modding android phones. With this forum as a guide, I was able to successfully root my phone and I am now runing the latest PG LG Motion cyanogen mod. The process was extremely well-documented and I felt that I was adequately prepared for every step. Thank you so much!
I opted not to install gapps and i am enjoying having a more lightweight android system. The only issue that I have run into so far is that gps simply does not work without gapps. I have tried replacing gps.conf and gps.default.so with my backed up stock versions, but the phone still refuses to get a fix after as long as 30minutes (after which time I gave up). I even tried replacing libgps.so and libgps.utils.so in system/lib to no avail...
I decided to experiment and tried a factory reset and fresh install with gapps and then gps worked flawlessly and got a fix nearly instantly. I am not a big user of gps services, so I reverted back to the non-gapps (and non-functional gps) system. I have also noticed that my battery life is much better without gapps. Even when gps was turned off, my phone ran hotter and put more of a drain on the battery with gapps.
Note: The battery was an issue before I even thought about rooting and modding the phone. When google updated google+ and maps a few months ago, I had noticed that my phone started running hotter and shorter as a result. I think this has something to do with the gapps location services and media server processes.
Is gapps absolutely neccessary to get gps working or am I missing something here?
Thanks again!
eviljim
Thanks again!
eviljim
