Is it possible to block cellular data using an app?
varmartins
Like the title says I would like to know if it is possible for an app to block all cellular data use. If so, how would I go about building such an app?
Welcome to Android Forums.
Under 4.4.4 you can useTasker actions of ...
Mobile Data Off to stop mobile data
WiFi Off to stop WiFi data
Under 4.4.4 you can use Tasker actions of ...
Mobile Data On to start mobile data
WiFi On to start WiFi data
... Thom
The app has already been built.
Automateit will allow you to turn Data off and on using shortcuts on your home screen.
All you need to do is define rules with a "manual trigger" and a Data on or off action.
You can then create shortcuts to these rules on your home screen.
Pretty slick for a free app. I use it all the time.
-Dave
I just discovered that under 5.1 a third-party app (Tasker) on an un-rooted phone can turn WiFi Off and On.
I went to WiFi | settings | Advanced and turn o everything but ...
Scanning always available
Avoid bad Wi-Fi connections
... and I can now toggle WiFi using Tasker.
(This is very important to me because I have a pair of Tasker profiles that turn WiFi off when I am away from the office and turn it back on when I return. This stops my phone from attempting to connect to WiFi networks ... like in a customer's office.)
... Thom
No ... it seems to be a glitch in the system WiFi control. I have now set everything in ... WiFi | Settings | Advanced ... back to the way they were and I can still toggle WiFi On and Off through Tasker on a never-been-root-ed Droid Turbo 64GB.
I just reproduced the problem on another phone (Droid Maxx running 4.4.4). There is no issue with 5.1. The issue was with the previous release of Tasker. When I upgraded to the most recent release of Tasker the problem disappeared and I could Toggle WiFi on and off.
So ... with the most recent release of Tasker I can toggle WiFi on 4.4.4 and 5.1.
... Thom
