sflannery07
Just wondering because I'm liking the leaked videos/images of ics and that's pure android. Be nice experience the pure android experience for a change
Swype (and all other apps) won't be affected, although TouchWiz-specific widgets will no longer work.
To revert back, you just "clear defaults" for the current launcher and the option menu will appear next time you hit the HOME button. Select TW, check "set as default" and you're back in Samsung-land.![]()
Tried installing another launcher, still no joy. I installed go launcher, still did not give me the option to clear defaults, no defaults set apparently. Damn you Samsung!
The touchwiz app drawer is the only reason I keep touchwiz, I have got so used to the pages of apps it gives, and the ability to order the apps in each page as I see fit. If any other launcher gave me that ability I would switch at the drop of a hat.
This can be done on Go launcher to.
Not exactly, I can't have 5 apps on page 1, 3 apps on page 2.....
It always seems to re-order them
Go to Settings/Applications/Manage applications and select (iirc) TouchWiz. At the bottom of the resulting screen is an option to "Clear defaults". Select that, hit HOME and you'll be given a choice of launchers. If the stock one has been left in by Samsung it will be there.
p.s. If stock Launcher is missing ADW Launcher (free in Market) makes a pretty good lightweight substitute.
