Help Is it possible to get the OTA JB 4.1.2 update again?
moycas
Hello all.
Recently, after the OTA update and the new Jellybean OS, I started to have problems with my warp sequent. Decided to download the ZTE Upgrade tool assuming that this would fix the issue. But what this tool did in the end, is a downgrade to the original 4.0.4 ICS and now it seems that there won't be another OTA update again.
I tried stopping the google services framework and looking for ZTE software several times without any success. Is there anyway to force the OTA besides this? or is there any place in which the update zip file can be downloaded to perform an upgrade using the bootloader?
Thanks in advance.
Kind Regards,
Moycas
You should be able to update it via ota. The servers never stop running. Just gotta wait. If 2 weeks passes by and you srill cant get the update do it manually with cwm with the partitions and such in a thread here.
