DsyMnapTic
Android Expert
Is it possible to potentially permanently screw up the hardware of my phone by setting the CPU at 748 when it can't handle it. Which in all actuality I'm not sure it can't. However when I set it to 748 using Playfulgods update my phone would constantly reboot itself. So I turned it down to 728 to see if it would operate properly then and the same thing happened.....so then I turned it back down to 710 and the same thing happened...
This lead me to believe that Either
1.setting my phone to 748 somehow damaged the hardware OR
2.There's a bug somewhere in the update (not saying anything PG, I think you did an awesome job, I'm just searching for answers)
I have on the otherhand reflashed Isaacs 521 and am running @ 710 once again without any issues whatsoever.......sooooo, I don't know maybe a bad download on my part on your ROM update PlayfulGod...I also did reflash it a few times with the same results?
