Root Is my phone bricked?...
Kushie
Okay, I have an HTC Incredible, with the Liqiud Metal ROM installed, I just accidentally wiped my SD card, and now when I boot up, It goes to the main setup screen for the LM rom. When I hit the android to start the setup, it does nothing. QQ
if your phone can boot up then its not bricked. bricked means nothing works, you cant even go to clockworkmod or anything. just reflash the rom, and wipe everything. and you should put this in the "all things root" section
Like the user above said, you're not bricked. You did lose everything you had saved on your SD card though
