gunsnroses
Member
as v know android version 3 already out but is used in samsung tabs and few other galaxy phones have android 2.2 which is upgradable til 2.3 but wht about samsung galaxy SII is it upgradable 2 any furthur versions?
is tht it nothing more than tht mine is 2.3
The next step is 2.3.4
There is no further upgrade written yet. It is the latest Gingerbread OS that exists!
What else do you want?![]()
i just read post here where upgrading till 3 is written didnt u check it earlier version 3 was in tablets but it is advanced 2 phones as well is it true or the post is fake?
omg... it is Android Market version 3.1.3 !!! this is not Android firmware... LOL
market version u mean 2 say where v get apps and games oh sorry iam new 2 this
No worries, so were we all once upon a time.
As well as the Android OS itself having specific versions such as 2.2.x (Froyo) and 2.3.x (Gingerbread), the core Google apps also have their own versioning.
This new version of the Market app has been pulled from an already-updated handset and made available for everyone. In time it will be rolled out automatically to all handsets, but this allows users avoid the wait.
It's already been rolled out
I think you will find that that is the old "new" Market (3.0.27) you received OTA.It's already been rolled out, I received the new version of the market around two weeks ago, it auto updated after using a market fix which must have cleared the cache or something.
for standard firmware 2.3.4 for CM7 rom and a few other based on CM7 2.3.5
This is version 3.1.3 which was only released 24th Aug.
If you go to Settings > Applications >Manage applications > All > Market... you can see which version you have.
Obviously not to everyone just yet though, or nobody would be installing this "new" version.![]()
i tried 2 search for update in market itself but i didnt get tht and how to update it where can i update from?
I was refering the to the new look market, not a specific version but yes it's 3.0.27.
Well no, if I never ran the market fix I would probably still be on the old market, plus it required root.
I'm not sure exactly why it updated but it was either after running the market fix from Chainfire 3D or after using market enabler, both require root.
If your rooted give them a try.
u need to be rooted to install 3.1.3 ver market ? actually nope. u don`t have to be rooted... just install it manually
