I'd be very surprised to hear that any modern rom isn't deodexed. If themes are available it has to be. I assume you're on the latest android version, 2.3.340?
Sounds like you want a Blurry rom. Normally only the bloat is removed and you still have all the Blur apps you're used to.
Rubix Blurry 2.3.320 comes to mind. Supposed to have a version updated for 340 out any day that improves battery life. I think it has a stock appearance.
Apex 1.31 is pretty good. You'll probably need to configure it a bit more since some of the Blur is removed by default. It has a black theme by default. I re-added the stock alarm clock, office and blur email.
Make your you're rooted, have recovery and a backup program like Titanium installed before installing any rom. You'll want to have a current Titanium (file) backup and at least one stock image (recovery) before installing a rom. That's your ticket to the next OTA.
You should be able to go from stock to either of these roms without a factory reset so you'll still have all your data and settings.
