Optimus_User
The kernel starts out well, and eventually reboots. Once it reboots, it starts a fit of reboots.
Does it even without being OC'ed![]()
When you installed it, did you just flash it? Try reflashing it but wrote cache and dalvik cache
Yeah that happened to me once in a while but not often. I switched to speedkernel
Sounds like fast boot-no offense to MT but my phone just doesn't play well with this kernel eitherSidenote: typically, the reboots are "mini." It skips the LG logo, and does the animation for fifteen seconds. When I reboot on purpose, it takes a minute to boot back up.
Lol overclocking is over rated :B but to each their own. I didn't notice any speed difference between the two. I suggest you try it out and see![]()
Or go down then back up and reroot-do it here about every 2 months(clean slate)I wonder if I should do a massive restore.
:thumbup:I love the Blitz kernel. Only reboots if I max out the OC. Sounds like a bad install OR it just isn't meshing well with your ROM.
It's the BO Rom, the one made for the kernel, haha. I'll do a total restore this weekend and see if it works. If not, eh, whatever.
