Help Is there a mobile data toggle widget?
JohnJSal
Android Expert
With all the other features on this phone, I'd be shocked if there isn't one, but for the life of me I can't find it.
Thanks.
Well would you mind sharing how to find it? I don't see it in the expanded selection of toggles in the notification bar.
I pulled down the notification bar with 2 fingers which shows all of the toggles.
I tried to upload an image but it is apparently too large...sorry.
Yes, I've seen all of those toggles, but what is it called? I'm looking at every one of them and none have to do with turning mobile data on and off.
The screen grab OnYourKnees posted has 19 of them little guys. My S4, courtesy VZW, only has 16.
I'm missing the Wi-Fi toggle (which I'm pretty ticked about, as I'd expected one), Air Gesture, and Blocking Mode (which I don't miss).
I underline my envy that you have a Wi-Fi toggle and I don't. I'm somewhat mollified by the fact that, whenever I pull down my notifications, I get "Wi-Fi off, Tap to turn Wi-Fi on" sitting there under "Ongoing," so it isn't a total loss.
Don't know if this is any use to you as it's based on the intensional S3.
Goto settings > display > notification panel to change the buttons that appear on the pull down list. Just long press each one to 'pick it up' and move to the opposite (enabled/disabled) part of the window.
If you don't have that option in settings, then I guess your respective carriers have screwed the pooch on you as far as that goes.
If all else fails, you can get a TON of settings widgets by downloading Elixir 2 from play ;) enjoy.
Other phone model users have made the missing widget with Widgetsoid. Takes some getting used to, but if in a settings path you can usually make a widget for it with that tool. Plus, it's free.
