Help Is there a running application logging program?
ned4spd8874
So, I just got my replacement Inc and after less than 24 hours, it rebooted on it's own again during a call.
I rooted the phone using unRevoked and then installed the Virtuous ROM using ROM manager. I also used Titanium to restore my programs and settings.
So, I'm wondering if I have a certain app that is causing problems? I really don't want to go through and remove each and every app one by one to figure this out. Any good logging programs out there, or does anyone have a good way to figure this out?
when you are using titanium to restore, are you restoring system data? that could be your problem. The other way to troubleshoot would be to uninstall all the apps from your phone and see if it still does it. Then install one by one.
