Running liberty3 right now...Is there a way to change how the stock messaging app handles sending pictures in an MMS? Frankly it just resizes the images too much and they come out all blurry....this was never a problem with the Blur app...it resized..but not as much...
Yes...the Blur app works fine for sending the messages...but I'd prefer the stock app if its possible to make it work
My issue with the Blur app on Liberty is this...when I'm on the screen that shows all of my conversations or in the app settings..when I scroll the white color becomes brighter until I stop scrolling and its quite annoying...
I tried finding a way to fix this for a couple of hours today and no luck. I am running Liberty 3 and didn't notice this until after you made this thread. It is quite annoying how small it resizes. I will let you know if I find a resolution.
