Root is this problem solveable???
darkworld260
so i need to flash S-off to say S-on but i have no clockwork recovery or SU commands and evey single unrooting guide that i have seen says you have to flash Unrevoked S-on tool through clockwork recovery so how do i change S-off to S-on?????? so far i havnt gotten an answer to that question :mad:
Also i havnt been using my phone in fear that i might mess it up some how and i need it tomorrow...
did you read this thread.? http://androidforums.com/evo-4g-all-things-root/249730-unrevoked3-your-firmware-too-new.html
try uninstalling any task killers or antivirus apps you have. also maybe on your computer try uninstalling HTC syn (if you have it on your computer). if you don't have it install it then uninstall it.
i did read that and i did a factory reset of my phone before i tryed to root to ensure of no errors.... so then now i just need to try and install HTC Sync and uninstall it cause it will give me the drivers i need?
First thing you need to do is make a backup.
Do that before you do anything else. That is what will get you out of trouble in the future.
