Root Isaac`s CM7 Overclock Kernel (Out of Date see notes in first post))
streetpounder
10/03/11 - This overclocking kernel is falling out of date compared to the recent fixes Ticker Guy has made to CM7. FFC will not work if you flash this kernel. This kernel does not include any of the latest modifications and improvements beyond the late September build. Use at your own discretion...
This is my attempt at putting Isaac`s last CM7 OC kernel into an flashable zip to flash over tickerguy`s 9/20 build of cm7. I just flashed this over mine and I can now overclock on Ticker`s ROM! USE AT OWN RISK. MAKE A NANDROID BACKUP IF YOU HAVE NOT ALREADY before proceeding with flashing this.I pulled the the BOOT.img and placed it into a flashable payload. Report back your results. Thanks!
Triumphant_CM7.zip
3107 on quadrant at 1.5GHz
This is my attempt at putting Isaac`s last CM7 OC kernel into an flashable zip to flash over tickerguy`s 9/20 build of cm7. I just flashed this over mine and I can now overclock on Ticker`s ROM! USE AT OWN RISK. MAKE A NANDROID BACKUP IF YOU HAVE NOT ALREADY before proceeding with flashing this. Also keep in mind I`m not sure if I did this right other than it worked on my phone a moment ago. I pulled the the BOOT.img and placed it into a flashable payload. I`m not sure what other things are in the boot.img that may break anything or if it is just the kernel. I just wanted to try the overclocking portion with Ticker`s GPS build. Report back your results. Thanks!
Triumphant_CM7.zip
Yes, that's all I was going to do. The boot image found in my last build is current against TG's latest build. It should stay like that for awhile.
Should I ever find time to add more cool stuff, like extra governors or whatnot, I'll provide an update boot image.
Wow cool. Glad I did it right then. Everything is cruising along since I flashed it. I`d love to see the extra governors down the line (scary, smartass, etc). Thanks again for blazing the trail Isaac!
There's only one thing that confuses me about using the boot image from my build with TG's latest, technically, it shouldn't even work. The init in my boot image mounts everything with ext4. I don't remember TG adding ext4 support into his builds, yet.
I thought he had added support but hadn`t done anything with it yet? is that right? I don`t remember where I saw him reference ext4. Too many threads on too many sites...
Ticker said he added ext4, but didn't want to mess with it or overclocking. I think it was the build with the WiFi fix in it.
I think that not only did ticker add ext4 support in the latest build, but he even said the next build after 9/20 would actually set itself up with ext4 partitions. Awesome all around.
This kernel seems to work fantastic so far:
Quadrant scores:
Tg's kernel from 9/20 @ 1 ghz: 2040
Issac's oc kernel @ 1 ghz: 2320
Issac's oc kernel @ 1.5 ghz: 3195
I happen to have one of those triumphs that won't go above 1.5ghz and be any sort of stable... :-D
Thanks to Isaac for the kernel and streetpounder for packaging it up for us! Awesome!
Thanks for this! Flashed to TG this morning, worked fantastic, great battery life improvement and this was the topping. The ability to 'crank it up' when needed, and increase the throttling.
2056 TG @ 1 GHz
2424 OC TG @ 1GHz
2997 OC TG @ 1.5GHz
3410 OC TG @ 1.9GHz (for kicks)
Hope to see more add ons and governors, and more so looking forward seeing how heat dissipation is at with these things over clocked.
Quadrant 2975 at 1.804 GHz. Thanks!
EDIT: Quadrant 3210 when removed live wallpaper and set minimum to 1.7 GHz with Performance governor.
ty for this work great but only get to 1.5 after that i start rebooting but 1.5 is good :)
cm7 and this kernel phone works like a charm now .
everything is working awesome with this. just flashed over to TG's build and flashed this over it and at first boot installed quadrant and setcpu with nothing else on the phone. pulled a 4249 on quadrant at 1900 with performance governor set. very nice i must say
Remember you shouldn't even need setcpu under cm7.... Cm7 will let you tweak the cpu speeds and governors in the performance tweaks section under cm settings. :)
Any input on settings for increasing battery life? For those running around 1.5, is your battery life better than the stock rom?
i know this but i must say that from what i've seen SetCPU actually controls the cpu a lot better then the standard cpu setting window in cm7. i noticed dramatic increases on quadrant of about 500-600 points when using SetCPU compared to just cm7's standard settings, and the fact that SetCpu allows for profiles, which i have all of mine set up and my battery lost 5% over the course of 9 hours while i slept last night and i left my phone unplugged purposely.... i use juice defender and have my internet set to cut off while my phone is asleep and come back on once an hour to refresh things like weather and facebook...... all in all i do believe SetCPU is the way to go with this. oh and one other thing dealing with this. if you do use this over TG's build of CM7 you will not be able to use MSS Calmping for tethering since it is kernel specific and TG's kernel include's it, but sadly enough this one does not...... yet. just saying..... hope all this helps
edit: on my profiles i have my main set to 1.7 max 2.45 min. when screen is off it drops to 1ghz max 245 min.
aww :/ if i didnt use the FFC alot i wouldnt mind doing without, thanks for letting me know issac before i installed. Is anyone currently fixing the issue which disables the FFC when using this btw?
Sorry for my noobness in advance. If I flash the 10/2 CM7 update, will this OC kernel be overwritten, or should I "unflash" this kernel first, then the 10/2 update? Thanks for helping out the noob.
Out of curiosity, is there any more work being done on this kernel to make it compatible with CM7? Or will there be an OC kernel made to work with CM7?
The kernel included with cm7 has everything this has, plus more. Including new features and bug fixes. That is why he discontinued it(as explained in his first post ).
